New 914 owner! Already dreaming of engine swaps..., What would you guys think about a 4A-GE blacktop in a 914? |
betz |
Nov 6 2018, 04:07 PM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
A little background: I have 3 cars besides the 914: A stock '00 Boxster, a restored '86 E30 BMW with a 2.8L stroker M20, and a '06 Outback XT. All manual trans.
I found this 1972 914 1.7 on craigslist for $1600 and the main selling point to me was that most of the parts were there, it just seemed to need some basic TLC to get it running. Also, its a California car and not a total rust bucket. Also hasn't appeared to be in any major accidents. After pretty much finishing my E30 I've been itching for a new project... Ideally smog exempt. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1541542078.1.jpg) The plan for the car is to get it running with the original type 4. The PO, who only had it for a few months, said he thinks it needs a fuel pump... turns out, the fuel pump wasn't even plugged in. So OF COURSE it's not running. He got it to start briefly with just starter fluid, so I'm thinking that's pretty much it. I'm going to bring it back to stock configuration on the D-jet, change out the oil and fuel, plug in the dang fuel pump in and I pretty much expect it to start up no problem. From there, I will get into the restoration phase. Take it down to bare metal (I believe the car was originally black, and has total crap paint job) tackle any rust, then repaint. Then get the interior/ exterior trim all sorted. And, if I get through alll that... I will probably want to undertake a motor swap, unless I'm just in love with the type 4. I tossed a few ideas out there, but my ideal motor would be a light, high revving motor with ITB's. Since S14's are not exactly obtainable, the 20V 4A-GE blacktop is my best idea so far. KEP makes an adapter for it, plus, it doesn't make enough power to break the stock 901 trans. I am a mechanical engineer with access to a machine shop, so fabbing some engine mounts, routing cooling system etc will most likely be pretty doable. What do you guys think? Am I in over my head? |
Tdskip |
Nov 13 2018, 07:28 AM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Going down a path that others have plowed is likely to give you a much better result, much quicker.
betz |
Nov 15 2018, 03:43 PM
Going down a path that others have plowed is likely to give you a much better result, much quicker. This is very true. Even partially plowed is better than nothing. Not going to lie. I'm strongly considering a type 4 build now. Which may or may not be related to the fact that the type 4 may be the absolute easiest motor in existence to fit ITB's to affordably. Looks like they sell 40mm and 48mm throttles for about $550 for all 4. (Why no middle ground??) Looking into it, I think the big bottleneck for a budget build is the heads. Ideally, I'd want to fit the biggest possible valves into my 1.7 heads as possible and do the whole spark plug relocation thing. I need to talk to some engine builders, I may have a contact with lots of experience with these heads. If I get the head figured out, seems like the hot ticket will be the 96mm cylinders, 78.4mm crankshaft, and a nice cam to compliment the setup. Wonder if I can pull 6-6.5k RPM out of this motor... what's the limiting factor besides the cam? From there, I've already decided what I want to do if I go down this path. Megasquirt with ITB's. 100%. I have absolutely 0 experience with carburetors so the whole idea of it being simpler and easier is not the case for me. When I set up the megasquirt with a proper tune I'll never have to worry about it being tempermental and it will run smoother than a carb'd car ever would. The only thing *not* making me want to build a type 4 is that jerk Jake Raby. Every damn thread about a type 4 build ends up with "you'd be stupid to try this yourself, the only way to have a good motor is to buy it from Jake Raby". And then Jake Raby chiming in "Years and years of R&D, we don't just toss components together, issall in the combooooooooo" Well, I may have only gotten my degree in mechanical engineering, but if I can toss together a type 4 motor that's 80% as good as a JaKe rAbY motor for a fifth of the cost, then I would consider that a major success. Is 150 crank hp achievable with this spec? |
Mike Bellis |
Nov 27 2018, 07:16 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Going down a path that others have plowed is likely to give you a much better result, much quicker. This is very true. Even partially plowed is better than nothing. Not going to lie. I'm strongly considering a type 4 build now. Which may or may not be related to the fact that the type 4 may be the absolute easiest motor in existence to fit ITB's to affordably. Looks like they sell 40mm and 48mm throttles for about $550 for all 4. (Why no middle ground??) Looking into it, I think the big bottleneck for a budget build is the heads. Ideally, I'd want to fit the biggest possible valves into my 1.7 heads as possible and do the whole spark plug relocation thing. I need to talk to some engine builders, I may have a contact with lots of experience with these heads. If I get the head figured out, seems like the hot ticket will be the 96mm cylinders, 78.4mm crankshaft, and a nice cam to compliment the setup. Wonder if I can pull 6-6.5k RPM out of this motor... what's the limiting factor besides the cam? From there, I've already decided what I want to do if I go down this path. Megasquirt with ITB's. 100%. I have absolutely 0 experience with carburetors so the whole idea of it being simpler and easier is not the case for me. When I set up the megasquirt with a proper tune I'll never have to worry about it being tempermental and it will run smoother than a carb'd car ever would. The only thing *not* making me want to build a type 4 is that jerk Jake Raby. Every damn thread about a type 4 build ends up with "you'd be stupid to try this yourself, the only way to have a good motor is to buy it from Jake Raby". And then Jake Raby chiming in "Years and years of R&D, we don't just toss components together, issall in the combooooooooo" Well, I may have only gotten my degree in mechanical engineering, but if I can toss together a type 4 motor that's 80% as good as a JaKe rAbY motor for a fifth of the cost, then I would consider that a major success. Is 150 crank hp achievable with this spec? Jake is a Marine and we have a very low bull shit tolerance. I actually love it when he rants. It reminds me of the good ole days... Semper Fi He is the best when it comes to the T4 engine but there are others that are also very good. HAM makes the best head modifications. You can now buy much of Raby's tech at the T4 Store and get on the waiting list for HAM to do your heads. Be prepared to buy new heads when HAM rejects them. Making good reliable HP in a T4 is not cheap. Main bearings can be hard to source. For the price of a good T4, you could drop a SBC with adapter kit and have money left for gas... |
Lo-Fi Version | Time is now: 23rd April 2024 - 04:44 PM |
