New 914 owner! Already dreaming of engine swaps..., What would you guys think about a 4A-GE blacktop in a 914? |
betz |
Nov 6 2018, 04:07 PM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
A little background: I have 3 cars besides the 914: A stock '00 Boxster, a restored '86 E30 BMW with a 2.8L stroker M20, and a '06 Outback XT. All manual trans.
I found this 1972 914 1.7 on craigslist for $1600 and the main selling point to me was that most of the parts were there, it just seemed to need some basic TLC to get it running. Also, its a California car and not a total rust bucket. Also hasn't appeared to be in any major accidents. After pretty much finishing my E30 I've been itching for a new project... Ideally smog exempt. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1541542078.1.jpg) The plan for the car is to get it running with the original type 4. The PO, who only had it for a few months, said he thinks it needs a fuel pump... turns out, the fuel pump wasn't even plugged in. So OF COURSE it's not running. He got it to start briefly with just starter fluid, so I'm thinking that's pretty much it. I'm going to bring it back to stock configuration on the D-jet, change out the oil and fuel, plug in the dang fuel pump in and I pretty much expect it to start up no problem. From there, I will get into the restoration phase. Take it down to bare metal (I believe the car was originally black, and has total crap paint job) tackle any rust, then repaint. Then get the interior/ exterior trim all sorted. And, if I get through alll that... I will probably want to undertake a motor swap, unless I'm just in love with the type 4. I tossed a few ideas out there, but my ideal motor would be a light, high revving motor with ITB's. Since S14's are not exactly obtainable, the 20V 4A-GE blacktop is my best idea so far. KEP makes an adapter for it, plus, it doesn't make enough power to break the stock 901 trans. I am a mechanical engineer with access to a machine shop, so fabbing some engine mounts, routing cooling system etc will most likely be pretty doable. What do you guys think? Am I in over my head? |
betz |
Apr 23 2019, 04:32 PM
Welp, after a half a year of deliberation I've come full circle back to the 4A-GE blacktop.
I found a mint one for about $1200, aka, for less than a K motor, fully dressed with wiring harness ECU etc and about 60k miles. Here it is: (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1556058757.1.jpg) Reasons I chose it over the K motor? ITB's. I'm sorry but I am a total sap for ITB's. I looked into ITB's on a K motor, It would be over triple the cost and way too much power for my little 914. I want to keep it at max 200 hp. Fitting it to a "regular" 4A-GE requires an adapter but would definitely be cheaper than the K. But I would still need to run an aftermarket ECU. I want this project to be, once the motor is running, it's running perfect. Tuning can be a total headache and expensive. Also, packaging wise, the ITB's coming out the side works super well in the rectangular 914 engine bay. Size. Dimension wise, the little 1.6L 4A is smaller in every dimension. Online I found it was 21" from bottom of oil pan to top of valve cover. That's shorter than an EJ. the K motor is around 26". Barely will clear the engine cover. Vision. I have an, erm... theme, in mind for my 914 once it's done. I will be embracing my little Toyota motor, I'll leave it at that (IMG:style_emoticons/default/wink.gif) I appreciate everyone's advice and I considered everything about this build but in the end I must follow my heart on this one or else I won't even have any motivation. New direction also, I will be starting with the engine first, so I don't get the car looking all pretty just to cut it up again. I plan on starting a build thread once I have some stuff to post, so stay tuned! |
Lo-Fi Version | Time is now: 28th March 2024 - 10:34 AM |
