New 914 owner! Already dreaming of engine swaps..., What would you guys think about a 4A-GE blacktop in a 914? |
betz |
Nov 6 2018, 04:07 PM
Member Group: Members Posts: 76 Joined: 22-October 18 From: San Leandro, CA Member No.: 22,593 Region Association: Northern California |
A little background: I have 3 cars besides the 914: A stock '00 Boxster, a restored '86 E30 BMW with a 2.8L stroker M20, and a '06 Outback XT. All manual trans.
I found this 1972 914 1.7 on craigslist for $1600 and the main selling point to me was that most of the parts were there, it just seemed to need some basic TLC to get it running. Also, its a California car and not a total rust bucket. Also hasn't appeared to be in any major accidents. After pretty much finishing my E30 I've been itching for a new project... Ideally smog exempt. (IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-22593-1541542078.1.jpg) The plan for the car is to get it running with the original type 4. The PO, who only had it for a few months, said he thinks it needs a fuel pump... turns out, the fuel pump wasn't even plugged in. So OF COURSE it's not running. He got it to start briefly with just starter fluid, so I'm thinking that's pretty much it. I'm going to bring it back to stock configuration on the D-jet, change out the oil and fuel, plug in the dang fuel pump in and I pretty much expect it to start up no problem. From there, I will get into the restoration phase. Take it down to bare metal (I believe the car was originally black, and has total crap paint job) tackle any rust, then repaint. Then get the interior/ exterior trim all sorted. And, if I get through alll that... I will probably want to undertake a motor swap, unless I'm just in love with the type 4. I tossed a few ideas out there, but my ideal motor would be a light, high revving motor with ITB's. Since S14's are not exactly obtainable, the 20V 4A-GE blacktop is my best idea so far. KEP makes an adapter for it, plus, it doesn't make enough power to break the stock 901 trans. I am a mechanical engineer with access to a machine shop, so fabbing some engine mounts, routing cooling system etc will most likely be pretty doable. What do you guys think? Am I in over my head? |
Chi-town |
Apr 24 2019, 04:43 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
That's not a mint one, that's your standard JDM importer spraying the whole thing down with clear coat. If that's where you got it there's no way it has 60k on it unless you got the front clip with the odometer to prove it. Most of those engines come out of 100k+ cars.
Contact Grant at Battle Garage for all the stuff you'll need to replace on it. He knows his 20v and stocks most of the hard to get parts. |
betz |
Apr 24 2019, 05:26 PM
That's not a mint one, that's your standard JDM importer spraying the whole thing down with clear coat. If that's where you got it there's no way it has 60k on it unless you got the front clip with the odometer to prove it. Most of those engines come out of 100k+ cars. Contact Grant at Battle Garage for all the stuff you'll need to replace on it. He knows his 20v and stocks most of the hard to get parts. Eh, maybe, clear coating seems unnecessary shady though. He did show me a pic of the engine just when it was crammed with all the other engines and it still looked pretty good although dustier. I don't see how they could get rid of all the oil spots and make it looks so nice just with clear coat. I feel like he just wiped it down with armor all or something but I was more looking at where all the gaskets meet and in all the crevasses where you would see some real problems that simple green wouldn't solve. As it stands I'll probably replace anything that's sensible to replace like the belts and probably timing belt and water pump gasket etc. In any case I've conceded this car is very far from a daily driver and I am putting what is still a Toyota engine into it. I'm not really too concerned. Thank you for the source for parts though, another reason I became less scared of this motor was that the aftermarket seems quite good and you can still find parts at reasonable prices even though it's a JDM motor. Also a lot of US 4A GE parts seem compatible or 4A FE so as long as you're a little resourceful it shouldn't be too bad to get stuff for it. |
Lo-Fi Version | Time is now: 28th March 2024 - 05:13 AM |
