Remove Front Shock Bushing?, Alignment Mount |
bbrock |
Nov 8 2018, 09:12 AM
Anyone have tips on removing the rubber bushings from the front shock alignment plate/mount without destroying them? I'd like to take this apart to clean and repaint but the bushings look great and I'd like to reuse them.
Thanks! |
BeatNavy |
Nov 8 2018, 09:17 AM
I used a press. It comes flying out of there, so be careful. I'm pretty sure it wasn't destroyed in the process, but I was replacing them with the 914Rubber version, and so I wasn't overly concerned. IIRC, the bushings are made of two separate pieces.
bbrock |
Nov 8 2018, 10:01 AM
I used a press. It comes flying out of there, so be careful. I'm pretty sure it wasn't destroyed in the process, but I was replacing them with the 914Rubber version, and so I wasn't overly concerned. IIRC, the bushings are made of two separate pieces. Thanks! So it comes out in one piece? I also thought it looked like two separate pieces of rubber but I can't tell if they are glued together. I also wondered if I could press out the metal center and then remove the rubber. Replacing with 914rubber bushings is my backup plan, but I hate to ruin perfectly good OEM parts. Or I could just clean and paint with them in place I guess. |
Lo-Fi Version | Time is now: 26th April 2024 - 09:24 PM |
