Remove Front Shock Bushing?, Alignment Mount |
bbrock |
Nov 8 2018, 09:12 AM
Anyone have tips on removing the rubber bushings from the front shock alignment plate/mount without destroying them? I'd like to take this apart to clean and repaint but the bushings look great and I'd like to reuse them.
Thanks! |
914Sixer |
Nov 8 2018, 10:02 AM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Leave them in and use a wire wheel to clean them up. Just put some HD tape on the edges.
bbrock |
Nov 8 2018, 11:15 AM
Leave them in and use a wire wheel to clean them up. Just put some HD tape on the edges. I think this is the smart route. No sense in sacrificing good original bushings and it sounds like removing them may be a one-way trip. Curious about those 2-piece replacement bushings. Do you glue them together on install? Thanks for all the advice. I learned something today! (IMG:style_emoticons/default/beerchug.gif) |
mepstein |
Nov 8 2018, 11:26 AM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Leave them in and use a wire wheel to clean them up. Just put some HD tape on the edges. I think this is the smart route. No sense in sacrificing good original bushings and it sounds like removing them may be a one-way trip. Curious about those 2-piece replacement bushings. Do you glue them together on install? Thanks for all the advice. I learned something today! (IMG:style_emoticons/default/beerchug.gif) The two piece bushings just press together. Pretty easy. I'm not sure you can really tell a bushing is good by looking at it. Rubber degrades over time but at least if it needs replacement, it's not hard to do after the fact. |
Lo-Fi Version | Time is now: 19th April 2024 - 10:03 PM |
