914 GT off set / back spacing with no spacers ? |
914GTSTI |
Nov 8 2018, 05:02 PM
Member Group: Members Posts: 269 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Keep looking but have not found the answer. This will be using the 4-130 pattern.
So what is the back spacing or off set for the front using a 8x15" wheel .And the rear using a 10" or 12" x 15 " for the rear.( if they will fit) Trying to not use a spacer. Thanks, Randy |
sixnotfour |
Nov 9 2018, 03:12 AM
914 Wizard Group: Members Posts: 10,392 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
the 15 mm offset of the 9x16 fit no problem.. the 3 mm offset of the 15s is a problem, as seen in my grn 814 pic,,,that being said,,I know a guy that cannot put any 9 inch under his rear flairs..
Attached image(s) |
914GTSTI |
Nov 9 2018, 09:36 AM
Lo-Fi Version | Time is now: 28th March 2024 - 06:26 AM |
