914-6 GT 3.2 conversion, Need some form of heat |
mb911 |
Nov 9 2018, 03:27 PM
914 Guru Group: Members Posts: 6,806 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Thanks Ben and everyone else that participated. I just wanted to explore all posibilites before I came to the obvious ( expensive ) conclusion. Our exchange rate is brutal at this time ! I totally understand.. Your just lucky your asking now rather then Jan 1 as my parts become much more expensive. |
Larmo63 |
Nov 9 2018, 05:19 PM
Running the oil lines down the driver's side rocker is an easy job. I did all of mine in an afternoon.
That would restore your lost heat tube inside the rocker to it's original configuration. |
Cairo94507 |
Nov 9 2018, 05:21 PM
Michael Group: Members Posts: 9,708 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
This is easy to say when I will not be writing the check, but Ben's heat exchangers and the hard GT lines is the way to go. Do it once, do it right and never worry about it again. (IMG:style_emoticons/default/beerchug.gif)
SKI-HI |
Nov 9 2018, 07:21 PM
Newbie Group: Members Posts: 8 Joined: 21-July 17 From: Alberta Member No.: 21,274 Region Association: Canada |
This is easy to say when I will not be writing the check, but Ben's heat exchangers and the hard GT lines is the way to go. Do it once, do it right and never worry about it again. (IMG:style_emoticons/default/beerchug.gif) I wish I wasn't writing the cheques either ! Its always been my motto to do it the right way but I'am glad I asked the question just in case someone had a eureka solution I didn't think of.When the car was built almost 20 years ago they didn't spare any expense but had limited options to deal with the oil lines. Fix it once and restore the heat. |
Nov 9 2018, 07:37 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
This is easy to say when I will not be writing the check, but Ben's heat exchangers and the hard GT lines is the way to go. Do it once, do it right and never worry about it again. (IMG:style_emoticons/default/beerchug.gif) I wish I wasn't writing the cheques either ! Its always been my motto to do it the right way but I'am glad I asked the question just in case someone had a eureka solution I didn't think of.When the car was built almost 20 years ago they didn't spare any expense but had limited options to deal with the oil lines. Fix it once and restore the heat. (IMG:style_emoticons/default/agree.gif) a lot of times these cars don’t get driven because they are a little to raw for our comfort level. It’s better to spend the money and drive the car than let it sit in the garage. It’s a hit to the wallet but Ben’s heat exchangers are built to last. Sell your headers and get some money back. How about some pics of the car. |
Steve |
Nov 9 2018, 10:03 PM
914 Guru Group: Members Posts: 5,568 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
This is easy to say when I will not be writing the check, but Ben's heat exchangers and the hard GT lines is the way to go. Do it once, do it right and never worry about it again. (IMG:style_emoticons/default/beerchug.gif) I wish I wasn't writing the cheques either ! Its always been my motto to do it the right way but I'am glad I asked the question just in case someone had a eureka solution I didn't think of.When the car was built almost 20 years ago they didn't spare any expense but had limited options to deal with the oil lines. Fix it once and restore the heat. (IMG:style_emoticons/default/agree.gif) a lot of times these cars don’t get driven because they are a little to raw for our comfort level. It’s better to spend the money and drive the car than let it sit in the garage. It’s a hit to the wallet but Ben’s heat exchangers are built to last. Sell your headers and get some money back. How about some pics of the car. (IMG:style_emoticons/default/agree.gif) It’s pretty pathetic having heat exchangers in so cal, but it is a nice creature comfort in the winter time early mornings or late at night. I will also add ac for the summer time, why not?? |
sixnotfour |
Nov 10 2018, 06:23 AM
914 Wizard Group: Members Posts: 10,410 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Heres your 914 ?
engine mount maybe a problem...I cant remember (IMG:style_emoticons/default/headbang.gif) Attached thumbnail(s) Attached image(s) |
Steve |
Nov 10 2018, 06:07 PM
If your running a cross bar motor mount, then heat exchangers won’t work. I upgraded to the firewall rich Johnson mount, just so I could run heat exchangers.
mb911 |
Nov 10 2018, 06:17 PM
If your running a cross bar motor mount, then heat exchangers won’t work. I upgraded to the firewall rich Johnson mount, just so I could run heat exchangers. I actually will defer to you on this.. I have never had a customer with that cross bar.. The nice thing is the bulkhead mounts can be bolted in if welding ia not your thing. |
SKI-HI |
Nov 10 2018, 07:15 PM
Good Catch !
Thats my car ,though I've been underneath it several times and it doesn't look that bad in person ! I'am not familiar with this mount you refer to . |
Mark Henry |
Nov 10 2018, 08:36 PM
Mark Henry |
Nov 10 2018, 09:14 PM
You have a "Quick 6" front engine mount, which uses the /4 mount points.
All other mounts, including stock, mount on the firewall and don't run under the engine. The Quick 6 bar is what will interfere with heat exchangers. |
SKI-HI |
Nov 10 2018, 09:30 PM
You learn something new everyday.
I priced out a new Rich Johnson mount and related parts. It will be about $ 1,000 CDN by the time I get it here. Heat is becoming very expensive |
sixnotfour |
Nov 11 2018, 05:13 PM
I have this in my 914-6,,,low 30amps hi 50.....at idle hard on alt. but moving no problem ..911 alternator.. I lived in WA. state...lottsa rainy days...instant heat.. they have all kinds of amp options
https://www.amazon.com/DC-THERMAL-SA12-5000...R/dp/B006VZSMYO here is me receiving my 914 thing.. Attached image(s) |
mb911 |
Nov 11 2018, 06:44 PM
Try mad dog motorsports engine mounts are less then 450 shipped
914forme |
Nov 11 2018, 07:05 PM
Nov 11 2018, 07:15 PM
sixnotfour |
Nov 11 2018, 07:58 PM
(IMG:style_emoticons/default/confused24.gif) How much heat does he want ? ..is the question
Mark Henry |
Nov 11 2018, 11:07 PM
Alberta... so he could drive a nice fall day, stop for evening dinner and come out to -10C (14F). Also in Alberta they don't use salt, so he may choose to drive on nice winter days, -30 (IMG:style_emoticons/default/huh.gif) |
sixnotfour |
Nov 12 2018, 10:21 AM
he may need 2 heaters.... (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 23rd April 2024 - 09:43 PM |
