Dyno'd the six, Fun day |
jfort |
Nov 9 2018, 10:00 AM
Senior Member Group: Members Posts: 1,135 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
Yesterday, Jay Kjoller and I took the six to Chris Moore, Autobahn Extremist in Avon Lake, Ohio to have it dyno'd. Newly rebuilt 2.7. A data point for you should you find it helpful:
Disp: 2.687 Bore: 90 mm Stroke: 70.4 mm Comp Ratio: 10.8:1 1966 aluminum case JE Pistons DC30/Mod. Solex (Dougherty) cams Ports: int 35 mm, exh 38mm Carbs: PMO 40 venturies 40 34 main jets 135 A/C's 185 idle jets 50 idle airs 130 E-tubes F1H DFI twin spark set at: Init 2°, 3000 25°, 8000 5° Chris measured 183HP at the wheels, so, assuming 15% loss, 210HP at engine car runs great. a good compromise for a mostly street car. I am happy. Chris has a wealth of Porsche knowledge, experience and skill. Great shop! Like Jay, a perfectionist. I would not hesitate to take a Porsche there. |
Chi-town |
Nov 9 2018, 10:12 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
On a Mustang dyno that's pretty respectable, they normally read about 5-7% less than a Dynojet or Dyna-pack.
TravisNeff |
Nov 9 2018, 10:13 AM
Nice! Any reason that you stopped at 6 grand, looks like you were still making power at the cutoff.
Nov 9 2018, 10:15 AM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Those aluminum cases make a great base for a hot rod motor. (IMG:style_emoticons/default/beerchug.gif)
wndsrfr |
Nov 9 2018, 10:36 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
You said "mostly street"....if you track it you may want to jet it richer based on the afr curve shown...
Chi-town |
Nov 9 2018, 10:43 AM
Looks more like the acceleration tip in at 2k (most dyno operators hold steady at 2k then floor it when they hit the green button) runs a bit lean then plays catch up but then corrects as it comes up on the the main jets as he ends up in the mid 12's / low 13's for most of the run.
Can you increase the accelerator pump output on a solex? What is your base timing and your max advance? |
JmuRiz |
Nov 9 2018, 10:51 AM
914 Guru Group: Members Posts: 5,424 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
180+ whp in a 914 must be a blast, good work!!!
flyer86d |
Nov 9 2018, 01:54 PM
Member Group: Members Posts: 422 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
Nice flat torque curve.
North Coast Jim |
Nov 10 2018, 07:41 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Yesterday, Jay Kjoller and I took the six to Chris Moore, Autobahn Extremist in Avon Lake, Ohio to have it dyno'd. Newly rebuilt 2.7. A data point for you should you find it helpful: Disp: 2.687 Bore: 90 mm Stroke: 70.4 mm Comp Ratio: 10.8:1 1966 aluminum case JE Pistons DC30/Mod. Solex (Dougherty) cams Ports: int 35 mm, exh 38mm Carbs: PMO 40 venturies 40 34 main jets 135 A/C's 185 idle jets 50 idle airs 130 E-tubes F1H DFI twin spark set at: Init 2°, 3000 25°, 8000 5° Chris measured 183HP at the wheels, so, assuming 15% loss, 210HP at engine car runs great. a good compromise for a mostly street car. I am happy. Chris has a wealth of Porsche knowledge, experience and skill. Great shop! Like Jay, a perfectionist. I would not hesitate to take a Porsche there. ..............and you didn't call me. Would have loved to be a part of that excercise. I live just west of there. You are correct that Chris runs a great shop. Met an talked with him at a couple of PCA events. Perfectionist for sure. |
Mark Henry |
Nov 10 2018, 07:42 AM
Great numbers for your specs. (IMG:style_emoticons/default/first.gif)
Mark Henry |
Nov 10 2018, 07:43 AM
dp
johnhora |
Nov 10 2018, 08:17 AM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
What fuel were you using for the dyno run?
Thanks |
Lo-Fi Version | Time is now: 2nd May 2024 - 05:46 PM |
