Brake bleed valve seat....calling all brake gurus |
raynekat |
Nov 10 2018, 06:16 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Just trying to get an answer over the weekend to a question I have.
I've got some new rear calipers going on the car and one of them is weeping some brake fluid. Hard to see exactly where it is coming from. Could be a bleeder valve or possibly a defect in the caliper casting. I have a question about the brake bleed nipple seat.....actually the very bottom where the end of the bleed valve bottoms out. See pic below: To me, the correct bottom of the bleed valve seat should be beveled to match the beveled point at the end of the bleed valve....such as the example on the right. My particular caliper has a seat bottom that is square like the example on the left. Not only do you get less surface area for the bleed valve to seat against possibly causing a leak even when the bleed valve is closed or tightened up....but if you tighten the bleed valve even a moderate amount, the square bottom will put a nice "step" in the bevel of your bleed valve. I don't believe that is an optimal situation or even wanted. Any thoughts or knowledge on this? I'm thinking I have an incorrectly machined bleed valve seat. I was thinking about taking a proper sized drill bit and putting a bevel down there, but the angle is not the same on the drill bit. On Monday I'll check with Eric at PMB for his take on this. |
raynekat |
Nov 12 2018, 03:06 PM
This bleed valve seat affair is turning into a non-issue.
Put some new bleeder valves in today and the caliper is still weeping from the thru bolt threads 2nd from the top. This is the bolt just beneath the upper fluid passageway that connects both caliper halves together. The area around the bleeder valve is bone dry. So either there is an issue with the square O-rings (or their mating surfaces) that seal both caliper halves or.... what I really believe. I think this caliper has a casting defect such that there is a micro fissure or void allowing fluid to travel from the brake fluid gallery directly into the thru bolt bore or hole. If so, it's terminal for this caliper. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:04 PM |
