Cylinder Head Temperature Sensor, Disconnect Scenario? |
JawjaPorsche |
Nov 12 2018, 04:05 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
My 73 1.7 FI engine starts normally. The AAR works great then my engine really runs rough until the engine warms up: usually three miles of driving. Especially bad in cold weather. A friend who also has a 914 suggested I disconnect the Cylinder Head Temperature Sensor to see if that would help and maybe isolate the problem.
Was wondering what to expect if I disconnect it. Needless to say, your input would be greatly appreciated. Thank you in advance. |
jim_hoyland |
Nov 13 2018, 06:55 PM
Get that VIN ? Group: Members Posts: 9,301 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
The AAR is easily bench tested... (IMG:style_emoticons/default/smile.gif)
Jamie |
Nov 13 2018, 07:23 PM
Senior Member Group: Members Posts: 1,031 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
Testing by what method Jim? I suspect this part might be a factor in my continuing idle searching problem. (IMG:style_emoticons/default/confused24.gif) |
jim_hoyland |
Nov 14 2018, 06:45 AM
Testing by what method Jim? I suspect this part might be a factor in my continuing idle searching problem. (IMG:style_emoticons/default/confused24.gif) Remove the AAR from the car. At ambient temp, or lower, the orifice will be open or partially open; the window shade inside is the moving part that regulates the air flow. Then attach a 12 volt source to the AAR's spade connectors, and note the time. A working AAR's window shade ( inside the AAR ) will being to close. Mine closes in 1 1/2 minutes. Thats it. |
Lo-Fi Version | Time is now: 18th May 2024 - 08:14 AM |
