Mahle - Magnesium Gas Burners, Wheel Refurbisher wanted |
porschetub |
Nov 13 2018, 10:14 PM
Exactly, a really good prep job ,etch primer then the right basecoat and clear with a quality product,then you have a real nice job...not really beyond any good paint shop if you aren't DIY.
burton73 |
Nov 13 2018, 10:31 PM
burton73 Group: Members Posts: 3,512 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Exactly, a really good prep job ,etch primer then the right basecoat and clear with a quality product,then you have a real nice job...not really beyond any good paint shop if you aren't DIY. The factory had some kind of Blue primer as base. Just For Your Info Bob B |
TravisNeff |
Nov 13 2018, 10:43 PM
The way this thread is going, the OP will need to learn how to smelt magnesium, pour some ingots, make molds, melt the ingots and cast the wheels.
I hear that sixnotfour has the recipe for the magnesium, easy peasy. |
Nov 13 2018, 10:57 PM
914 Idiot Group: Members Posts: 14,982 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Sorry for the question, but do these come in both Mag and aluminum ? What about pedrini's ? These are original 914-6 or 911 wheels. They're made by Mahle, and are magnesium. There are reproduction ones currently made out of aluminum. They are rather heavier. I'm not sure if they have 914-friendly offsets, as they are generally intended for the Bug market. They are available with several bolt patterns, including "wide five" and "narrow five" as well as four-bolt. Note that these are not the same as the four-bolt Mahle 914 wheels. The four-bolt Mahles are aluminum, and are a bit heavier than the four-lug Fuchs (when I weighed some). They are four-lug only, and come only in one size and offset, and are intended for 914s. The Pedrini wheels you refer to are similar to the 914 Mahles but not identical. They are also aluminum and were made for 914s. --DD |
porschetub |
Nov 13 2018, 11:03 PM
TravisNeff |
Nov 13 2018, 11:05 PM
Everyone is making this into something a whole lot bigger than what it needs to be, it's just paint. The wheels may be special, but the finish is not.
porbmw |
Nov 13 2018, 11:15 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
understood
It is just paint... And powdercoating is likely a hazard to the end product....and most assuredly Porsche did not powder coat BUT "what"..is the "just paint". Anyone know the color code, etc that Porsche used... I, for one, would like to know, as I plan on doing my own "someday" (IMG:style_emoticons/default/biggrin.gif) |
raynekat |
Nov 13 2018, 11:28 PM
Advanced Member Group: Members Posts: 2,158 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
I agree with those saying just use auto paint.
No powder coat. I would never put a magnesium wheel in an oven, period. Plus if you ever need touch ups in the future, ya going to touch up the powder coat? Normal car paint is easy to body work and touch up. Just get the correct silver paint and get a good shop to paint and clear it. Done deal. |
sixnotfour |
Nov 14 2018, 02:44 AM
914 Wizard Group: Members Posts: 10,422 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Be aware Harvey is in the middle of Fire watch in Oroville, CA..maybe a little hard to get a hold of at the moment..
ConeDodger |
Nov 14 2018, 06:27 AM
Apex killer! Group: Members Posts: 23,578 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
TravisNeff |
Nov 14 2018, 08:54 AM
The wheels may be special, but the finish is not. The point is, it’s not just a wheel... I am going to need more convincing before I can agree with you (IMG:style_emoticons/default/poke.gif) All kidding aside - a previous post stated that the primer may be a blue color. So I did some searching and found that there may be a conversion coating or special chemical dip that helps seal the metal so there can be better long term success with paint http://www.vintagebonanza.com/prep_magnesi...or_painting.htm https://www.pfonline.com/articles/painting-magnesium |
ConeDodger |
Nov 14 2018, 09:35 AM
The wheels may be special, but the finish is not. The point is, it’s not just a wheel... I am going to need more convincing before I can agree with you (IMG:style_emoticons/default/poke.gif) All kidding aside - a previous post stated that the primer may be a blue color. So I did some searching and found that there may be a conversion coating or special chemical dip that helps seal the metal so there can be better long term success with paint http://www.vintagebonanza.com/prep_magnesi...or_painting.htm https://www.pfonline.com/articles/painting-magnesium I admire your confidence Travis. I agree, you can just paint it. With some skill, you might make it look very good. My point is of course that Harvey would know exactly what that blue primer is and he would use it. If you visit his shop you’ll get a tour and he can show you factory original wheels in original condition. He will then restore yours better than that. My point is that the value and rarity of the wheel calls for extra care. Here’s an example of Harvey’s work. Anyone can anodize a wheel. Harvey’s processes include a pretty precise temperature for the anodization tank. He won’t tell the process. These wheels are now about 6 years old and still flawless. That’s tough. I don’t baby them... Attached image(s) |
TravisNeff |
Nov 14 2018, 09:43 AM
How long was the wait for Harvey to do his magic?
Nov 14 2018, 09:54 AM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Nov 14 2018, 10:10 AM
BUT "what"..is the "just paint". Anyone know the color code, etc that Porsche used... Silver. (IMG:style_emoticons/default/biggrin.gif) I have read somewhere around here that Wurth silver wheel paint is a very good match to the original paint. Don't know how true that is. --DD |
TravisNeff |
Nov 14 2018, 10:16 AM
How long was the wait for Harvey to do his magic? He usually takes a year /-. Like people said, it's just paint but there are times where you want something 100% perfect. For wheels it's Harvey. That is quicker than what I heard. At one point someone shared that the running backlog was 18+ months a few years back. There are more players who are restoring porsche wheels now with a faster turn around time. |
napasteve |
Nov 14 2018, 11:18 AM
914 driving winemaker Group: Members Posts: 501 Joined: 2-January 13 From: Napa, CA Member No.: 15,327 Region Association: Northern California |
Data point: Back in 2013, I purchased a set of 6x15 flat Fuchs from Harvey. He sourced the wheels, refinished them and put tires on them. It took 8 months. I'm really pleased with the wheels.
raynekat |
Nov 14 2018, 12:22 PM
I've heard Harvey is more like 2 years now.
sixnotfour |
Nov 14 2018, 01:51 PM
GeorgeRud |
Nov 14 2018, 04:54 PM
I pray he and all the others in these areas remain safe. As far as the Mahle wheels, I’d be more concerned about their structural integrity than the absolute correct share of silver paint.
Lo-Fi Version | Time is now: 7th May 2024 - 10:18 AM |
