Cleaning MPS and Decel Valve, Adivce needed |
doug_b_928 |
Nov 14 2018, 06:23 PM
Senior Member Group: Members Posts: 691 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
Just wondering what is the best way to clean these and if there's anything I need to make sure NOT to do. For a cosmetic cleaning of the outside I was thinking just some brake cleaner. Debris is visible inside the small port on the decel valve (debris can be seen in the third pic below) and I'm not sure the best way to get it out. Failing any advice to the contrary, I thought I'd gently insert a paper clip and dig it out. (P.S. I did the vacuum, resistance, and continuity tests on the MPS and it looks good).
JeffBowlsby |
Nov 14 2018, 07:08 PM
914 Wiring Harnesses Group: Members Posts: 8,477 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Small wire brush and elbow grease. Rattle can them, they will look great.
914_7T3 |
Nov 17 2018, 07:33 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Yes on the elbow grease, but no go on the paint. I opted for very fine steel with some new spacers from 914Sixer and repainted the mounting plate.
Came out great! |
TheCabinetmaker |
Nov 17 2018, 10:39 PM
A clear coat will keep them looking good longer. It seems to tarnish rather quickly.
JeffBowlsby |
Nov 18 2018, 03:50 AM
Your bracket is mounted backwards.
doug_b_928 |
Nov 18 2018, 10:53 AM
Thanks guys. The wire brush (copper) worked great. I agree on not painting them. Last year when I was doing the pedal cluster the advice was not to clear coat unpainted metal because it peals. The MPS cleaned up easily and really nicely so I think I’ll leave it and just repeat when it gets tarnished. Just waiting for the satin black on the bracket to cure and that will be another job off the list (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 24th April 2024 - 06:19 PM |
