Trunk Latch, Should this nut be attached? |
bbrock |
Nov 16 2018, 07:31 PM
With a lot of heat and PB Blaster, I managed to turn a fused mass of rust and hardware into these parts. I think the nut on the left that fits on the backside of the latch plate is supposed to be tack welded to the plate, but it came off relatively easily compared to how tightly all the other parts were conjoined. Can anyone confirm that nut should be welded to the plate? I'll tack a new nut on before sending to the platers if that is the case. If it isn't, adjusting the post height makes no sense.
Thanks again smart people. (IMG:style_emoticons/default/beerchug.gif) |
rgalla9146 |
Nov 16 2018, 07:46 PM
No, it is not attached.
Both nuts have to be loosened to make an adjustment. The shaft does not rotate. |
bbrock |
Nov 16 2018, 07:54 PM
No, it is not attached. Both nuts have to be loosened to make an adjustment. The shaft does not rotate. Ah Duh! Didn't think it through with the flat sided shaft. Thanks! (IMG:style_emoticons/default/beer.gif) |
cary |
Nov 16 2018, 10:18 PM
Brent do you still have the perch ?
http://www.autoatlanta.com/Porsche-Trunk-L...1204110PVP.html http://www.autoatlanta.com/Porsche-Upper-T...1451204111.html |
bbrock |
Nov 17 2018, 12:21 AM
Brent do you still have the perch ? http://www.autoatlanta.com/Porsche-Trunk-L...1204110PVP.html http://www.autoatlanta.com/Porsche-Upper-T...1451204111.html No, I don't. The wide part broke off a long time ago so I chucked the stump that was left. Thanks for the links as I will need to get a replacement. |
Lo-Fi Version | Time is now: 29th April 2024 - 01:28 AM |
