1973 914/911 Autocross Special |
916S |
Nov 18 2018, 01:28 PM
I'm new here ... Group: Members Posts: 0 Joined: 11-July 11 From: Penngrove, CA Member No.: 13,301 Region Association: None |
I've got too many projects so selling this mid engine autocross special. It's a tube frame chassis with 914 running gear and mounts to accept a 911 engine with side shift 914 trans. Has custom front upper A arms and shortened struts. Chassis needs to be disassembled, powder coat the frame, A arms etc and reassemble. Professionally built with excellent welds. Probably needs a front sway bar and lower the chassis a little, then align it after installing 911 motor and side shift 914 gearbox. Then build a cool body for it. Also have a rusty '73 914 project car that I'll include as part of the deal so you can use the side shift in the autocross special. Asking $3450 for everything. Sold with bill of sale only. Located in Penngrove, CA Email for more pix at kwiky59gt@yahoo.com
David.laRuse |
Nov 20 2018, 03:17 PM
Newbie Group: Members Posts: 3 Joined: 3-February 15 From: Cedar Rapids Member No.: 18,397 Region Association: None |
What are the dimensions? Is the kart the same as a 914? David.
916S |
Dec 15 2018, 10:55 AM
916S |
Jan 7 2019, 10:54 AM
New Years (IMG:style_emoticons/default/icon_bump.gif)
916S |
Feb 9 2019, 02:17 PM
Spring is right around the corner. Here's the basis to build your ultimate autocross car! |
jd74914 |
Feb 11 2019, 02:04 PM
Its alive Group: Members Posts: 4,776 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I'm not a buyer, but am curious...
What dampers are on the front? They have to have damping reversed from typical (bump now rebound, etc.) since the action is backwards. |
Lo-Fi Version | Time is now: 25th April 2024 - 07:45 AM |
