Need some quick help, Accelerator to carb linkage |
ericoneal |
Nov 19 2018, 04:33 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
Chi-town |
Nov 20 2018, 10:31 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
A cross bar set up isn't that bad if it's set up correctly.
Every set up has play in it, if you take the time to make sure everything is tight and aligned correctly it will work just fine. After looking at my parts car that has the same linkage as your car the ferrule on the end of the cable is intact and held into the linkage. I'll snap a few pics in a sec. |
ericoneal |
Nov 20 2018, 10:44 AM
Thanks!
I'd like to stick with what I have because it has worked great so far. I pulled the engine a couple weeks ago and disconnected everything except the accelerator cable. snap! Doh! Ran the new cable to the pedal last night, what a job that was.. A cross bar set up isn't that bad if it's set up correctly. Every set up has play in it, if you take the time to make sure everything is tight and aligned correctly it will work just fine. After looking at my parts car that has the same linkage as your car the ferrule on the end of the cable is intact and held into the linkage. I'll snap a few pics in a sec. |
Lo-Fi Version | Time is now: 17th May 2024 - 11:53 PM |
