Type 4 rebuild questions |
mepstein |
Nov 19 2018, 08:14 PM
914-6 GT in waiting Group: Members Posts: 19,271 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
What can I do to rebuild my 1.7 for more HP and torque but keep the original d-jet.
piston and cylinders crank camshaft heads ? I know I can't change the cam too much but is there one that will do better and still work with d-jet. I know there is modern FI but I'm not interested. No carbs. I'm not looking for all out HP or dropping 10K on an engine kit. I just want a nice bump in power, if possible, while keeping a stock looking engine. |
914forme |
Nov 21 2018, 04:31 PM
Source a 2.0L bus intake and that keeps the D-Jet it flows more evenly that the stock 2.0L Porsche stuff did according the Jake. Bigger injectors, and change fuel pressure and get it dialed in. Jake was getting 2056s to pull what?
I would build it to a 2.0L and eurospec or even a slightly higher bump in compression. And if you feel like spending the coin, Tangerine makes a great header. taking weight out of the car is a lot easier way to do it. Now if you're going to take every part and replace it or remake it to be lighter I'll subscribe to that build thread. Did I hear Titanium |
Lo-Fi Version | Time is now: 16th May 2024 - 02:27 AM |
