Stearing bearing lube, What to use |
trojanhorsepower |
Nov 19 2018, 08:58 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
So, i am about ready to reattach the stearing column, but i need to lube the shaft stablizing bearing, so what are your recommendations ? Grease, oil, weight?
Thanks All, Peter |
Mark Henry |
Nov 19 2018, 09:54 PM
I use swepco 101 grease on just about everything.
On a bushing where I want a bit stickier/thinner I mix some 101 grease with a dab of blue STP or Lucas engine assembly lube. I've used oil mixed with some blue STP in my oil can for years, great for anywhere you want oil that's a bit sticky. For T1/T4 engine assembly, lathe slides and anything you shoot with the oil can. |
Krieger |
Nov 20 2018, 12:16 AM
Advanced Member Group: Members Posts: 4,705 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
(IMG:style_emoticons/default/agree.gif) I do exactly the same. Great minds think alike!
trojanhorsepower |
Nov 20 2018, 04:31 PM
Thanks Guys!
Ill see if I can find the Swepco 101. Thanks again, Peter |
Mark Henry |
Nov 20 2018, 05:20 PM
trojanhorsepower |
Nov 20 2018, 09:28 PM
Thanks
Lo-Fi Version | Time is now: 3rd May 2024 - 02:39 PM |
