Stearing bearing lube, What to use |
trojanhorsepower |
Nov 19 2018, 08:58 PM
Senior Member Group: Members Posts: 861 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
So, i am about ready to reattach the stearing column, but i need to lube the shaft stablizing bearing, so what are your recommendations ? Grease, oil, weight?
Thanks All, Peter |
Mark Henry |
Nov 19 2018, 09:54 PM
I use swepco 101 grease on just about everything.
On a bushing where I want a bit stickier/thinner I mix some 101 grease with a dab of blue STP or Lucas engine assembly lube. I've used oil mixed with some blue STP in my oil can for years, great for anywhere you want oil that's a bit sticky. For T1/T4 engine assembly, lathe slides and anything you shoot with the oil can. |
Lo-Fi Version | Time is now: 22nd May 2024 - 04:51 AM |
