What's the best way to test a fuel pump? |
electrolime |
Jun 18 2005, 09:26 PM
Newbie Group: Members Posts: 5 Joined: 11-June 05 From: Venice, FL Member No.: 4,257 |
I need to check to see if the fuel pump is functioning on my 74 1.8. The wiring for it on the car is not there so I just need to test it manually. How do I just test to see if the pump will work? I bought this car as a non running project.
Thanks -Pat |
Trekkor |
Jun 18 2005, 09:31 PM
There are two terminals on the pump. + and - .
Run a wire to each with crimp-on connectors and touch to battery terminals. go, no-go. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) KT |
campbellcj |
Jun 18 2005, 09:33 PM
Inlet hose in container of gas, outlet hose in empty container, 12VDC to hot lead, negative to ground...
ArtechnikA |
Jun 19 2005, 09:54 AM
at some point you'll also need to know that it an deliver rated pressure; FI cars are very sensitive to fuel pressure.
after you've verified that it starts and runs (no not run it very long dry - like seconds, tops) you'll need to hook up a fuel pressure gauge. use one that goes to 100 psi - good pumps can deliver a LOT of pressure against an infinite restriction. past that, there's volume delivery data in the manuals. |
Lo-Fi Version | Time is now: 18th May 2024 - 07:39 PM |
