FS: 2.0 Stock D Jet Components, SOLD |
914_teener |
Nov 22 2018, 10:01 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
As the title says:
$800 including shipping to lower 48 for all. The MPS is calibrated for a 2.0 and has been tested as are the ECU's. Distrubutor for the 2.0 has a bad vaccum pot but the other dizzy is fully functionally and runs well with good vaccum pots. Rob (IMG:style_emoticons/default/mad.gif) |
914_teener |
914_teener |
Nov 22 2018, 10:02 PM
More
Attached thumbnail(s) |
914_teener |
Nov 22 2018, 10:03 PM
914_teener |
914_teener |
Nov 22 2018, 10:04 PM
914_teener |
Nov 22 2018, 10:05 PM
JOEPROPER |
Nov 23 2018, 07:10 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
Wow what a great deal!
914_teener |
Nov 25 2018, 11:04 PM
914_teener |
Nov 27 2018, 09:28 AM
I.ll deliver free in the local So Cal area for members.
Last of my 2.0 stuff. Only reason I.m selling it is that I have a darkside six project now. |
914_teener |
Nov 30 2018, 11:10 AM
This comes with the two 2.0 ECU's which have been tested as good.
2.0 Air Filter newly powder coated and a new air filter. 2.0 Throttle Body with TPS good. I.ll post more pics later. 2.0 "Green Top" fuel injectors. These came out of another car and were good then. I have tested the pintles and they do click. The should be cleaned and spray tested. Normally this goes for about $100. Working AAR Completely rebuilt MPS and tested. The kit was from Chris Foley and was calibrated by Jeff Bowlsby. Have the reciepts. This alone is more than $250. Two dizzy's. One is a 1.7 and the other from a 74 2.0. Powder coated silver 2.0 intake runners. 2.0 intake plenum pressure tested to 12 psi. No leaks. This has not been powder coated. Oil filler tower. Flamethrower coil. You will need a fuel pressure regulator and a harness to complete a conversion. |
Nov 30 2018, 12:13 PM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
914_teener |
Dec 3 2018, 12:03 AM
Pm's responded to.
Jazzy |
Dec 3 2018, 02:45 AM
Newbie Group: Members Posts: 32 Joined: 16-September 17 From: The Netherlands Member No.: 21,432 Region Association: Europe |
914_teener |
Dec 3 2018, 09:31 AM
Jazzy |
Dec 3 2018, 10:31 AM
Tdskip |
Dec 4 2018, 07:32 AM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Thanks Rob, I will put these to good use.
Lo-Fi Version | Time is now: 7th May 2024 - 08:44 AM |
