1.7 return fuel line routing |
Tdskip |
Nov 23 2018, 05:20 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
As part of getting the 1.7 ‘73 BAT car into regular use I need to tidy up the return fuel line. Does anyone have a picture of where the return if you wind it runs in the engine compartment before it ducks down under the horizontal sheet metal to the return line near the engine firewall?
Does it run up the passenger side engine compartment above the engine level so it’s not subject to heat? Thanks! |
orangecrate |
Dec 15 2018, 12:24 PM
Member Group: Members Posts: 152 Joined: 16-September 13 From: Apache Junction AZ Member No.: 16,394 Region Association: Southwest Region |
(IMG:style_emoticons/default/stromberg.gif) Sorry. I was 180 off on the direction of fuel flow. Bassakwards. Fuel pressure regulator is the last thing in line before return to the tank. Not first. So supply line runs across the engine and return across the aft firewall. Ooops. (IMG:style_emoticons/default/rolleyes.gif)
Lo-Fi Version | Time is now: 18th May 2024 - 10:23 AM |
