Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
IronHillRestorations |
Nov 27 2018, 09:50 AM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
How long did it sit? My guess is the fuel that was left in the carb float bowls evaporated down and has gummed them up.
Based on reading your replies, I'd start by pulling all the jets and soaking them in carb cleaner. That said, the best thing would be to pull the carbs, disassemble, clean/soak, put in a new gasket kit, put them back on the car. I'd change the fuel filter too, regardless. |
Lo-Fi Version | Time is now: 9th May 2024 - 05:46 PM |
