Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
Spoke |
Dec 9 2018, 10:48 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The item on the side of the distributor is the vacuum advance can. I doubt that the distributor is causing your issue. Going back to your first video, the engine turns over strong then chugs. It revs to about 3k RPM before dying. Nothing in the distributor would cause that except points.
It seems to me that your problem is fuel related. Have you tried starting fluid before starting to see if it revs up? |
Lo-Fi Version | Time is now: 18th May 2024 - 06:02 PM |
