Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
ericoneal |
Dec 31 2018, 01:22 PM
Hard question to answer. I dont know where the shims were installed because there was really just shards left (what you see in the picture). They seemed, from what I could tell, to be around the crank and behind the the main seal.
I found this set of flywheel shims online: Flywheel Shims - Pack Of 5 but you mention: "..the bolts for the flywheel go through the shims and into the hub. " but I dont see any way for a bolt to go through these. Are you referring to the flywheel washer? Flywheel washer If so, the yes, that was there. |
Lo-Fi Version | Time is now: 12th May 2024 - 04:24 AM |
