Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
Tdskip |
Nov 26 2018, 12:16 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
If you didn't move the distributor when the engine was out - and it ran fine before - leave it and focus on the wiring connections. Don't think the timing would change by itself.... One thing at a time!
Before moving on to anything else you may want to see if it will run well on ether. EDIT - if the wiring is OK and it runs on ether then it might be floats / fuel level. Keep us posted. |
Lo-Fi Version | Time is now: 27th April 2024 - 10:32 AM |
