Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
IronHillRestorations |
Nov 26 2018, 01:52 PM
I. I. R. C. Group: Members Posts: 6,714 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Spark, air, fuel, compression. It's one of those.
Start with making sure your ignition is working right; timing (including dwell), firing order is correct, and make sure your all other ignition components are good. I have a spark tester where you can see the spark, and adjust the air gap to make sure you're getting a hot enough spark. I'd pull your points and make sure they are good. Look at the distributor cap and make sure the center contact hasn't come out. Check the resistance of your coil. Replace the condenser if it's suspect at all. Make sure your plugs aren't fouled and the correct heat range for a carb'd engine. Make sure you are getting enough fuel. I personally have bent a rubber fuel hose enough to restrict fuel flow to cause a problem. Some fuel hose is more susceptible to this. I personally haven't used propane, but I've been told you can blow propane down the carb throats enough to get an engine to run. I've put gas in a mist bottle and sprayed it in the carbs (using protective leather jacket and gloves) but I'd consider it a risky move if you aren't set up to do it (adult help, fire extinguisher, etc). |
Lo-Fi Version | Time is now: 27th April 2024 - 03:12 PM |
