Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
ericoneal |
Nov 27 2018, 08:36 AM
I sprayed fluid in the carbs and it fires up easier, but still runs like the same, like crap...
Is there details or a walk through somewhere for cleaning these things? Do I need to tear them down, or can I just shoot some carb cleaner on them? |
mobymutt |
Nov 27 2018, 09:16 AM
Senior Member Group: Members Posts: 548 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
I sprayed fluid in the carbs and it fires up easier, but still runs like the same, like crap... Is there details or a walk through somewhere for cleaning these things? Do I need to tear them down, or can I just shoot some carb cleaner on them? I also vote for gummed up carbs. When you press the accelerator like that, don't the carbs pump in extra fuel via a different circuit of some sort? There are tonnes of videos on YouTube, see if you can find one you like. Here's a random link I found: https://the-bug-club.webs.com/cleaningwebber44jets.htm |
Lo-Fi Version | Time is now: 28th April 2024 - 09:27 AM |
