Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
ericoneal |
Nov 27 2018, 11:54 AM
Sent the video to a local guy here who is very good and he also suspects the carbs, in particular the linkage, and whether it may be out of adjustment.
I have VERY good reason to think that the linkage was mucked with egregiously when I pulled the engine out. What say you guys? Are these the symptoms of a badly adjusted dual carb linkage? I double and triple checked all of the wires and I'm pretty sure my electrical connections are good and its getting plenty of fuel form the pump. |
Lo-Fi Version | Time is now: 28th April 2024 - 11:42 AM |
