Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
Tdskip |
Nov 27 2018, 12:26 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
You should be able to disconnect the bar and set each carb to idle and fire it up.
I'd try than and report back. |
Mblizzard |
Nov 27 2018, 12:31 PM
You should be able to disconnect the bar and set each carb to idle and fire it up. I'd try than and report back. If this works seriously look into the CSP bell crank linkage. Some people have good luck with hex bar set ups but I have never been able to get them to stay set. Likely operator error I know! |
Lo-Fi Version | Time is now: 27th April 2024 - 11:29 PM |
