Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
marksteinhilber |
Nov 28 2018, 02:09 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
You have unsteady firing from a number of cylinders, but there is fuel so the car runs. It could be a carb or ignition problem. How do you know you have a strong spark at each plug? How old are your plugs and plug wires? Are any of the plug wires arcing to metal where they are touching. Plug wires will show where they are discharging to metal grounds. For this reason I make sure none of my plug wires are touching metal or each other by looming them and by using zip-ties to make wire separators. Check for fouled plugs. They should not have excessive gap or wear, nor excessive deposits. A spark checker or an inductive timing light placed right before the spark plug can tell you if one or more of your plug wires is grounding out to metal. Once you are sure you have a strong spark at each plug, then you can start to look for erratic fuel delivery problems. If you have a dual carb set up, it may then be caused by clogged jets or an adjustment on one or more barrels. Might be a good time to check the balance of flow and re-tune.
Lo-Fi Version | Time is now: 27th April 2024 - 09:45 PM |
