Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
ericoneal |
Nov 28 2018, 03:35 PM
I will double check the spark tonight by pulling the plugs and watching them. Previously just used timing light on plug wire to check for spark.
Fuel lines are not kinked, checked those. Will post back. THanks for all of the suggestions everyone. |
cgnj |
Nov 29 2018, 05:05 AM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
I will double check the spark tonight by pulling the plugs and watching them. Previously just used timing light on plug wire to check for spark. Fuel lines are not kinked, checked those. Will post back. THanks for all of the suggestions everyone. Watched the video. you are clearly running on pump jets, till you flood. I'm going to assume that you pulled the carbs off to drop the motor. you have at least two problems, one you have already repaired (loose/ intermittent connection at coil). Take off the engine lid if it is still on. Check the throttle stops and make sure that both carbs are on the idle stop. Clean the idle jets and replace. Take off air cleaners, operate the linkage and observe that each bore squirts. try to start car. two pumps on throttle, throttle close then twist key. If it fails to idle, seat each mixture screw counting the turns on each bore and write them down,observe if any are more than 2.5 turns. Seat the air bypass screws (only one should be open on each side). It's ok for all of theem to be closed, but not 2 open on a single side) Try to start the car using th method already described. You want to avoid using the pump jets two much, Let it stall if it wants to, it should run longer as it warms up. hope this helps, Carlos |
Lo-Fi Version | Time is now: 27th April 2024 - 03:08 PM |
