Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
sdoolin |
Nov 29 2018, 07:33 AM
Member Group: Members Posts: 359 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
Watched the video also. I think you have a linkage problem, engine is likely only running on one side or the other at idle.
I have a uni-syn tool and like 30 years of experience living with dual carbs running off of a hex bar linkage, and I am 20 mins away. PMd you and should be able to assist this weekend. |
ericoneal |
Nov 29 2018, 11:30 AM
Thats why this website is great. PMed received, will call you at 5:00 to set up a time and to chat further.
Thanks all! Also, and I may neglected to mention this. The reason that I took the linkage off was because I couldnt remove the throttle cable from the linkage. It appears that someone completely rounded out the set screw. I have a new cable on there, but it is likely not attached correctly. Anyway, there is enough slack so that the linkage returns to idle, so I really dont think that is a contributing issue, but be aware. Watched the video also. I think you have a linkage problem, engine is likely only running on one side or the other at idle. I have a uni-syn tool and like 30 years of experience living with dual carbs running off of a hex bar linkage, and I am 20 mins away. PMd you and should be able to assist this weekend. |
Lo-Fi Version | Time is now: 27th April 2024 - 09:37 PM |
