Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
sdoolin |
Dec 1 2018, 09:02 AM
Member Group: Members Posts: 359 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
As Eric said, not a fuel issue. We removed and cleaned idle jets and main jets (they were clean but we double checked). Oh, and for the record my Dellortos are MUCH easier to work on - but that is another story. All accelerator pumps pushing gas, and carbs are synched well from side to side. Certainly well enough to run. Impressive flames out of the tops of the carbs seems like a timing issue. We did double check and it seemed correct (but Eric had a shit selection of beer so who knows if the timing was right).
Removed the number 2 plug and it was sooty and black, but dry. Then we lost battery. I think Eric is gonna replace plugs and wires (and maybe battery) and give it another shot before towing it. |
Lo-Fi Version | Time is now: 27th April 2024 - 11:24 AM |
