Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
cgnj |
Dec 1 2018, 11:23 AM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
basics 101
At this point, I would jack it jp put in 5th and and confirm tdc ##1 but observing the valves. then confirm the rotor is point towards the index mark on distributor. Im anal, since I already dug in this far I would check the valve lash on all four any way. If the timing is correct is mechanically correct, I'd target coil, points distributor, plugs wires. |
Lo-Fi Version | Time is now: 28th April 2024 - 06:36 AM |
