Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
injunmort |
Dec 1 2018, 01:29 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
do you have access to a timing light? how are you sure timing is correct. sounds like you need to reset static timing get the engine running and then set it with a light. if you are getting flames out of the carbs, you have a timing issue.
ericoneal |
Dec 1 2018, 01:34 PM
do you have access to a timing light? how are you sure timing is correct. sounds like you need to reset static timing get the engine running and then set it with a light. if you are getting flames out of the carbs, you have a timing issue. We put the engine at TDC, according to the fan, and the rotor was pointing at plug wire #1. Is there something else more to it than that? Wondering if one or two of the sparkplugs are not firing now when cranking. Of course the battery is dead (I hope thats what it is), so it will be until tonight before I can test that.... (IMG:style_emoticons/default/headbang.gif) I have no idea what else to try. |
Lo-Fi Version | Time is now: 28th April 2024 - 06:53 AM |
