Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
injunmort |
Dec 6 2018, 09:27 AM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
yes, there is more to it than that. are you running points or electronic? with the engine on tdc on #1 compression, rotate distributor until points start to open. lock it down. put rotor/cap back on and start. warm up and then put timing light on #1. rev past 3500rpm and set your timing on the advance mark before tdc. done by loosening distributor and rotating until the marks align.
ericoneal |
Dec 6 2018, 09:48 AM
Thanks, I'm familar with timing the engine once its running, but at this point its only running for a split second unless I mash on the gas.
I think my next step is to be sure TDC is accurate although I have confirmed that the fan mark has the distributor pointing at plug wire one, then it should be. Going look at valves and mark on the fly wheel tonight as a double check. yes, there is more to it than that. are you running points or electronic? with the engine on tdc on #1 compression, rotate distributor until points start to open. lock it down. put rotor/cap back on and start. warm up and then put timing light on #1. rev past 3500rpm and set your timing on the advance mark before tdc. done by loosening distributor and rotating until the marks align. |
Lo-Fi Version | Time is now: 28th April 2024 - 01:52 AM |
