Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
rhodyguy |
Dec 6 2018, 01:25 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,063 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Try turning the idle up using ONE idle speed adjusting screw. Just one. Dr side is most convenient. Now you have some weird linkage bind out of the equation and you can get a pretty high idle speed if needed. Did you go with the old carb to intake gaskets? I consider them a one time use item. Go thru the whole carb preinstall setup, Cb manual, air-cooled.net, etc. you'll be time ahead starting from scratch. Show us your linkage. How much does your cross bar shift side to side?
Lo-Fi Version | Time is now: 28th April 2024 - 02:32 AM |
