Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
Rand |
Dec 6 2018, 05:11 PM
I haven't read the whole thread. But you know the basics. Assuming compression hasn't suddenly changed, how have you test for spark and fuel? If you put a plug on a wire and ground it, does it spark? Ten seconds. Fuel gets a little more timely, but not hard. You have to answer fuel and spark before this continues spiraling. Timing and tuning comes AFTER that.
Lo-Fi Version | Time is now: 27th April 2024 - 02:49 PM |
