Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
Spoke |
Dec 7 2018, 06:48 PM
Jerry Group: Members Posts: 6,977 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
In the video, your first key turn resulted in the engine firing up and running strong for a second or 2. I'd guess that the timing is ok and the plugs are correctly routed.
Tdskip |
Dec 7 2018, 08:39 PM
Advanced Member Group: Members Posts: 3,684 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
In the video, your first key turn resulted in the engine firing up and running strong for a second or 2. I'd guess that the timing is ok and the plugs are correctly routed. With all of the changes might be a good idea to get a new video of how she sits as of now posted. |
Lo-Fi Version | Time is now: 27th April 2024 - 10:27 PM |
