Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
ericoneal |
Dec 7 2018, 09:15 PM
I got the new starter on today, so at least I am back at square one and she it turning over again. A new video woundnt be worth much as its still doing the same thing.
I set TDC again today with the fan and rotor pointing at plug one. THen got under the car and checked #1 valves. I could move the intake and exhaust rockers slightly and they were gapped perfectly, so that valve is closed(?), indicating true TDC. Also checked a mark I made on the flywheel for valve adjustments and it was there. I tried a new distributor cap that I had in the basement, and nothing. I triple checked the plugs and even moved them 90 and 180 degrees to test. So at this point we know: The carbs are clean and somewhat adjusted TDC is true and static timing should be on I'm getting a spark on all four plug wires Its getting fuel. Next, I plan to check gap on the points. They were open at TDC, but maybe too much? Also found a spare coil to try. I have three more days to get this thing running.. Thanks for all of the suggestions guys, please keep them coming. |
Lo-Fi Version | Time is now: 27th April 2024 - 08:43 AM |
