Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
ericoneal |
Dec 9 2018, 11:50 AM
After spraying, it takes a few times, then starts for 1-2 seconds at a high rpm like before, then dies.
Spoke |
Dec 9 2018, 12:32 PM
Jerry Group: Members Posts: 6,977 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
After spraying, it takes a few times, then starts for 1-2 seconds at a high rpm like before, then dies. So with proper fuel, it revs up? I think you've hit the nail on the head. It appears you have some type of fuel issue. If you have problems with timing, valves, distributor, points the engine likely wouldn't roar into action even with the starting fluid. |
Lo-Fi Version | Time is now: 28th April 2024 - 02:22 AM |
