Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
injunmort |
Dec 9 2018, 02:54 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
you have still not timed it. yes the distributor and engine are at tdc, but you have not rotated the distributor into correct position. at tdc, on #1, the points should just start to open. I do this by a piece of cellophane between the points, rotating the distributor until the cellophane comes out of the points with light pressure. everything can be pointing in the right direction and it is still not statically timed.
Lo-Fi Version | Time is now: 28th April 2024 - 03:45 AM |
