Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
ericoneal |
Dec 11 2018, 09:35 AM
I'm starting to think its a fuel pressure issue myself, although it shot gas into bottles when the pump was on, maybe its crapping out after ignition?
As far as timing, we already set TDC and rotated the distributor each way while cranking with no luck. Anyway, time is now up, and she is off to the clinic: Will let you guys know what they find. |
Lo-Fi Version | Time is now: 27th April 2024 - 05:44 PM |
