Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
ericoneal |
Dec 17 2018, 09:31 AM
So as suspected all along, the problem would turn out to be something small and embarrassing:
I left a washer between one of the carbs and the head. (IMG:style_emoticons/default/WTF.gif) causing a huge vacuum leak. So it fires up and runs great now, the mechanic also sorted out some other issues and dumbassery (not all mine) that he found in the engine bay as well. But all is not well: I drove her home Satuday night (20 miles or so) and she dumped two quarts of oil out of the connection between the transmission and engine. So rear main seal? Its bad. Really bad... I didnt change the seal when I did the clutch because it never leaked and I didnt want to mess with the flywheel and all that could go wrong with getting that back on. Is it possible for this seal to get damaged when inserting the transmission shaft back on during re-install? How/why did this happen now? |
dr914@autoatlanta.com |
Dec 17 2018, 09:58 AM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I would say that it blew out a galley plug to spill that much oil
So as suspected all along, the problem would turn out to be something small and embarrassing: I left a washer between one of the carbs and the head. (IMG:style_emoticons/default/WTF.gif) causing a huge vacuum leak. So it fires up and runs great now, the mechanic also sorted out some other issues and dumbassery (not all mine) that he found in the engine bay as well. But all is not well: I drove her home Satuday night (20 miles or so) and she dumped two quarts of oil out of the connection between the transmission and engine. So rear main seal? Its bad. Really bad... I didnt change the seal when I did the clutch because it never leaked and I didnt want to mess with the flywheel and all that could go wrong with getting that back on. Is it possible for this seal to get damaged when inserting the transmission shaft back on during re-install? How/why did this happen now? |
Lo-Fi Version | Time is now: 27th April 2024 - 11:55 AM |
