Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
injunmort |
Dec 30 2018, 07:46 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
there are no shims behind the seal. that's whats left of the seal springs. looking at pre seal removal, its pretty obvious where the seal failed. new seal and reassemble. galley plug looks like it has indian head smeared on it and probably not the worst idea.
wndsrfr |
Dec 30 2018, 08:01 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
there are no shims behind the seal. that's whats left of the seal springs. looking at pre seal removal, its pretty obvious where the seal failed. new seal and reassemble. galley plug looks like it has indian head smeared on it and probably not the worst idea. IIRC There certainly are supposed to be three shims sandwiched between the flywheel and the end bearing surface....looks to me like the remains of a badly rashed shim there and if that's the bearing surface it's rashed also... |
Lo-Fi Version | Time is now: 28th April 2024 - 02:38 AM |
