Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
injunmort |
Dec 30 2018, 07:46 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
there are no shims behind the seal. that's whats left of the seal springs. looking at pre seal removal, its pretty obvious where the seal failed. new seal and reassemble. galley plug looks like it has indian head smeared on it and probably not the worst idea.
914_teener |
Dec 31 2018, 12:21 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
there are no shims behind the seal. that's whats left of the seal springs. looking at pre seal removal, its pretty obvious where the seal failed. new seal and reassemble. galley plug looks like it has indian head smeared on it and probably not the worst idea. Shims are there for crank end play which you will need to reset since they are destroyed. Have the flywheel checked for balance and wear. It could be bad or installed incorrectly. Good thing it is just a TIV. The DMF's in the newer P cars' are expensive. |
Lo-Fi Version | Time is now: 28th April 2024 - 07:19 AM |
