Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
injunmort |
Dec 31 2018, 01:05 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
if that is in fact shim remains, it was installed in the wrong place. the seal goes into the journal, the flywheel goes into the seal and is bolted up with shim on the flywheel. not behind it. see the pin on the crank, that corresponds to the flywheel, nothing in between. the shim as mentioned is for crank endplay. the bolts for the flywheel go through the shims and into the hub. the only way you could get shim remains back there with seal remains is if it was istalled in the wrong place. to confirm this I pulled the clutch on a motor I have in the garage there is the shim on the flywheel. io pulled the flywheel, seal that's it. when you pulled the flywheel bolts to remove it, was there a shimplate between all the bolts holding them to the flywheel? if not, there is your answer.
Lo-Fi Version | Time is now: 28th April 2024 - 06:00 AM |
