Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
ericoneal |
Dec 31 2018, 02:45 PM
Yeah, I'm with you on all of that. Just concerned as to how these shims could get destroyed like that. Flywheel was very tight when I took it off.
Car seems to run just fine except for the oil leak. I also dont know what size shims to buy now. Looks like I will need to mail order them blindly unless there is a correlation between the measurement with 0 shims vs the various thicknesses offered. |
Lo-Fi Version | Time is now: 27th April 2024 - 01:50 PM |
