Wont start, struggling |
ericoneal |
Nov 26 2018, 07:56 AM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I took my engine out (dual carburetors) awhile back to put in a new clutch. Reinstalled the engine and now it wont start unless I pump the accelerator pedal like crazy. Also, the tach is not working which seems to indicate maybe a coil problem?
I am getting plenty of fuel in the carbs and a spark on all for plug wires. I tried also rotating the distributor slightly each way to check that maybe it was a timing issue, but that did nothing. Like I said, the car starts if I pump the gas pedal, but will not stay running if I do not. Stumped. Any ideas guys? I'm sure its something simple, this thing ran great before... Anything else to try would be helpful. THanks |
ericoneal |
Jan 8 2019, 09:01 AM
worn |
Jan 8 2019, 10:21 AM
can't remember Group: Members Posts: 3,149 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Can you post a picture of the mating surface of the flywheel? Also, is the oil hole under the seal open to the inside of the case? It seems wise to understand the cause of the shim destruction before reassembly. I am thinking that the aluminum case isn't going to chew up steel shims, but maybe they dried up and got really hot. |
ericoneal |
Jan 8 2019, 10:32 AM
Good thinking. I will double check the surface tonight. I think the oil hole is indeed open because it was leaking like a sieve through the rear seal.
My suspicion, from looking at the remnants of the shims compared to the new ones that I have now, is that mayne the wrong diameters ones were used. But who knows for sure? Can you post a picture of the mating surface of the flywheel? Also, is the oil hole under the seal open to the inside of the case? It seems wise to understand the cause of the shim destruction before reassembly. I am thinking that the aluminum case isn't going to chew up steel shims, but maybe they dried up and got really hot. |
Lo-Fi Version | Time is now: 28th April 2024 - 12:10 AM |
