75' with 1.8 and Italian Weber Carbs, Needs hell hole replaced and bottom of rear firewall |
Chi-town |
Nov 27 2018, 12:02 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Originally I was going to part this out because I could make more money on it.
The fact of the matter is I'm lazy and figure I'll try and sell it whole first. This ad will be up til Sunday (12/2) after that it will be parted out. I brought this car up from Dallas not running or moving. It has a clean Texas title without mileage stated. Mechanicals: I've got it running on the Webers but it needs someone more patient that I to get it to 100%. I have installed a brand new Carter 3psi fuel pump and NGK spark plugs also. It also has CB performance Hex Bar linkage. Fuel tank is pretty clean inside, I rattled a chain around in there and nothing knocked loose. I did tap the outlet and return bungs for 1/4" NPT so no more leaky nipples. The 5 speed was rebuilt by the PO, there are a few threads from him here that I can share to back it up. I have it driving but as usual the front end seems a little loose. Exterior: It was disassembled for paint so all the trim retainers and misc are in the trunk with spares (he took apart a second car) It comes with a set of spare doors as whoever painted it dropped the LH door while trying to reinstall it. comes with 2 LH and 2 RH windows also. The paint is crap and has sanding scratches under the clear everywhere. They also filled the front marker light holes. The hell hole is covered up by a piece of sheet metal and braced with a piece of angle iron. It will need extensive work. The bottom of the firewall will also need replaced. Long on the LH side is good but they cut off the Jack point, RH side long will need repair in the rear. It has Mahle baby gas burners on it but the tires are dry rotted from sitting. the matching spare Mahle is there also. It has back dated chrome bumpers front and rear but the front lip for the big bumper has not been cut off nor has the bumper shock holes been filled. Top is in decent shape Interior: The fresh air system is missing completely and there is a hole in the dash panel (comes with spare dash) LH seat has foam but no upholstery, RH seat needs re-done also. Arm rest is in decent condition. Dash & Targa bar are cracked No visors / kick panel speaker mounts/ center console / Carpet Door panels are wavy and recovered in generic vinyl Back pad looks decent LH seat belt has issues Leather wrapped steering wheel (decent shape) The Long & the Short of it: No, you cannot drive the car home, I don't send people out in unsafe cars. Yes, you can drive it up and down my street slowly to confirm it will do it. I need to cover the cost of the car and transport so the price is $2500 Cash only, sorry no checks or paypal. It's located in Anaheim, near Knotts Berry farm If you are serious about buying it I can email specific pictures that you request. (IMG:http://www.914world.com/bbs2/uploads_offsite/beta-static.photobucket.com-22446-1543341736.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/beta-static.photobucket.com-22446-1543341737.2.jpg) |
Tdskip |
Nov 27 2018, 12:08 PM
Advanced Member Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
FYI gentlemen, seller is a good guy and straight shooter.
Chris914n6 |
Nov 27 2018, 03:43 PM
Jackstands are my life. Group: Members Posts: 3,316 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
sway bars?
Chi-town |
Nov 27 2018, 05:17 PM
PO removed them
914_teener |
Nov 27 2018, 10:47 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
If you don't sell it, can I have first dibs on the gasburners?
Thanks Rob |
Chi-town |
Nov 27 2018, 11:12 PM
Tdskip- has first dibs on the wheels and steering wheel. If he passes you're next up.
Chris914n6 |
Nov 28 2018, 12:23 AM
Chi-town |
Nov 28 2018, 12:52 AM
@chris914n6 Trunk, headlight buckets and front trunk are all solid.
PM me an email address and I'll send them over |
Chi-town |
Nov 29 2018, 09:22 AM
Due to space constraints I have to start disassembling this today, thanks for the interest.
JOEPROPER |
Nov 29 2018, 11:20 AM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
IF the firewall section where the fuel lines come thru is good, then I'll take it.
joeproper. |
Chi-town |
Nov 29 2018, 11:55 AM
Nope rotted out on this one too.
I have another car I just picked up I'll check that one once the rain stops. |
g8dixon |
Nov 29 2018, 05:30 PM
I'm new here ... Group: Members Posts: 0 Joined: 29-November 18 From: Scotland Member No.: 22,686 Region Association: None |
Chi-town |
Nov 30 2018, 10:18 AM
Pending
Lo-Fi Version | Time is now: 6th May 2024 - 03:23 PM |
